Oh, you experts
Old Jun 13, 2006 | 07:30 AM
menefreghista's Avatar
Default RE: Oh, you experts
slip-on is mostly cosmetic - save up for a full Ti sys & PCIII
do the flapper mod for starters & suspension/brakes next so that you'll be able to use the stock horsepower a lot better
Old Jun 13, 2006 | 08:45 AM
Eddie1000rr's Avatar
ORIGINAL: deezuhl
if you are looking for all the HP you can get then dont start off with a slip on.. go with a full system. you can get a nice akrapovic for around 900.. if you arent overly concerened with extra power than do the slip on but dont waste your money on the PC3.. you wont need it with the slip on. the bike is filthy rich stock.. good luck..
Hey Deezuhl, I currently just have a slip on....what kind of gains do you think i would be looking at on a full system? does it change the whole power curve? As u may have seen me post before...My bike gained some weight with the tire kit an dswing arm and I have some makin' up to do.
Thanks~Eddie
Old Jun 14, 2006 | 01:36 AM
deezuhl's Avatar
alot of the gains with full system will come from 10k up.. the low end is still good with a slipon.. the curve does change completly but for the better. it should be much flatter and not have as much of a curve to it.. slipons usually good for 3-4hp and full system if you choose a good one would be 8-12 easily.. i would go full ti if you are lookign to save weight. the weight is about 14lbs savings for a full ti system.
Old Jun 14, 2006 | 10:58 PM
SirJAG's Avatar
Deezul,
does that mean that with a full system you will lose low end?
and if i get a yoshi slip on, will i lose some low end as well, with the removal of the butterfly thingy in the exhuast?
thanks,
james
Old Jun 15, 2006 | 02:05 AM
deezuhl's Avatar
with the full system you do lose alittle bit down low cause there is less backpressure.. i dont know much about slipons or the butterfly sorry. i have never done a slip on.. im sure someone here can give you some info tho..
Old Jun 15, 2006 | 09:24 AM
chainstretcher's Avatar
Admin Emeritus & MVN
My advice is don't worry about a smidge of power lost below 3500rpms -- it's not important I swear. Heck, I launch at over 4000rpms. So unless you really like to lug your bike it's just not an issue. It's sort of like a truth in advertising kinda thing: yes Virginia, you do lose a bit-o-power in the lower rpm range with a slip-on or full system. But like deezuhl points out, it flattens out your curve and makes more power where you can really use it. It's not like you're gonna go ***** to the wall into a curve then up shift to 6th and exit it at 2800rpms ... that'd just be silly[8D]
Old Jun 15, 2006 | 11:01 AM
SirJAG's Avatar
your right chain.....
thanks guys
Old Jun 28, 2006 | 01:58 AM
dwhite645's Avatar
ORIGINAL: chainstretcher
ORIGINAL: OldFatGuy
I'll be 48 in the fall.... when you young pups catch up, lemme know.
... AND you're fat, eh? ha ha ha
Nah, he's not fat. I've ridden with him a few times. He is OLD though, that's for sure...hahaha...just kidding Duane
Old Jul 19, 2006 | 07:54 PM
Hans's Avatar
Well I had to post to this one.
54 and still going. CBR1000RR 2006
8500km in 7 weeks!!! What a rush.
Luv reading all the posts.
Hans
Old Jul 21, 2006 | 12:35 AM
all you old farts are kids compared to this 79 yr old guy i met on AFH ... big papa was riding an 06 red/black and also had a CRF450 for the trails
vfrman
Sep 23, 2013 10:41 PM
jvalentine86
F2 Tech
Aug 9, 2010 08:13 PM
PWRMAD
Mar 30, 2009 12:39 AM
Shadowart
Apr 15, 2008 10:52 PM
coxie
Mar 7, 2007 10:03 PM
