need help on jardine rt-1 dual installation!!
Old Feb 5, 2007 | 09:39 PM
vspriderz's Avatar
Default need help on jardine rt-1 dual installation!!
i'm trying to install my exhaust but i'm kinda confused. on the instructions, it says that i'm supposed to disconnect the exhaust valve cable from the actuator on the left side of the motorcycle and remove the cables. it doesn't say anything else about re-installing them. am i supposed to just get rid of the cables or what? please i need your help!!!!
Old Feb 5, 2007 | 10:19 PM
hell_razor's Avatar
Default RE: need help on jardine rt-1 dual installation!!
You do not need to re-attach them. Once you disconnect them, fish them out and leave the servo motor mounted to the stock pipe.
Old Feb 5, 2007 | 10:53 PM
vspriderz's Avatar
oh ok. great! thanks so much! i was starting to get worried for a minute there. what do those cables do anyways?
Old Feb 6, 2007 | 12:04 AM
Demon RR's Avatar
ORIGINAL: vspriderz
pitch them in the trash.
Old Feb 6, 2007 | 03:06 AM
hell_razor's Avatar
IIRC, the actuator and cables/motor help adjust the f/a mixture of the exhaust, and possibly increase backpressure. It helps the bike breath better at lower RPMs with the stock exhaust. This will not be a problem with the RT1 dual.
Old Feb 6, 2007 | 04:34 PM
vspriderz's Avatar
koo. thanks for the info razor!
Old Feb 6, 2007 | 05:11 PM
hell_razor's Avatar
You will love the way it sounds!!! Good luck!
bieniu
Sep 14, 2007 10:42 AM
arkansashog2
Jul 9, 2007 10:45 PM
2006f4ido
Jul 8, 2007 09:30 PM
Tony2wheels
Apr 27, 2007 01:44 AM
DWT74
Mar 10, 2007 10:20 PM
