Lowering link problems
Old Apr 30, 2007 | 08:45 PM
CBR1000PhoDragon's Avatar
Default Lowering link problems
Ok I know you all hate these questions but I just need some quick advice. I tried lowering my 06 1000rr this past weekend and had a little trouble getting the bolts off of the existing link. I can get the bolt closest to the rear wheel off but i cannot for the life of me get the second bolt closer to the engine off. If anyone has done this successfully please help me out. Thanks everyon
Old May 1, 2007 | 12:09 AM
tmj1000rr's Avatar
Default RE: Lowering link problems
You can't get them loose or you can't slide them out?? Which one? If you can't slide them out you have to get the back of the bike off the ground. Then lift up on the rear wheel and slide out. I did mine with no problem. When you put it back together do the rear one first.
Old May 1, 2007 | 12:40 AM
I cant slide the bolt out. I got the first one out by the wheel and all pressure is off of the second one but cannot slide it out.
Old May 1, 2007 | 02:48 PM
tmj1000rr's Avatar
Put the nut back on it a little bit and give it a tap. It should just slide out.
Old May 6, 2007 | 01:16 PM
GraveyLastGearMC's Avatar
do you have any pics of it lowered...if so please pm me with them im looking to do my 07...and how many inches did you do front and back...thanks
Old May 6, 2007 | 11:29 PM
tmj1000rr's Avatar
Gravey I have a couple of pic's posted in the 1000rr section under FINALLY DONE
whitewashed
Jun 28, 2013 09:39 AM
jtboyd91
Jul 23, 2010 08:24 PM
delta
Apr 4, 2006 03:27 PM
