PC-III Accelerator Pump Feature
Old May 5, 2007 | 01:16 PM
WolfPack's Avatar
Default PC-III Accelerator Pump Feature
Anyone using the accelerator pump feature on their PC-III.....i originally didnt enable it when i put in the PC-III.......whos using it, what mods do you have, and what setting/duration are you using...
just curious
My bike is stock.....PC-III.....RS-5 SlipOn.....Flapper-Mod.....Used for mostly joy-riding.....long trips....and to work and back
thanks
Old May 5, 2007 | 08:17 PM
MgA_ODEN's Avatar
Default RE: PC-III Accelerator Pump Feature
90,15,20 here. It keeps the A/F ratio from spiking lean when the throttle is abruptly opened.
When the throttle is opened rapidly there is some interpolation of the map values by the ECU and it cannot match the fuel to the volume of air rushing past the butterflies.
This is a tool that helps alleviate this condition.
As for mods ......
Akrapovic Ti Evolution System
Dynojet PCIII with Acc Pump Utility
BMC Air filters - Race
Intake Flapper Valve mod
Old May 6, 2007 | 11:44 PM
Sargeant Shitbag's Avatar
I use it, you can feel a diferance. 85 12 20
Icefox
Nov 30, 2008 04:50 PM
doogstar
Feb 24, 2008 12:51 PM
lifties
Feb 14, 2007 12:43 AM
blade17fire
Aug 18, 2006 02:19 AM
arkas
May 29, 2006 10:18 PM
