HIDs with 08 1000rr
Old May 13, 2012 | 08:30 PM
The__Rider's Avatar
Default HIDs with 08 1000rr
Just ordered a set of HIDs from DDM Tuning for my 08 1000rr. I was looking at the bulb housing for the headlights and wondered where the wiring will exit to connect to the ballast from the bulb. There's a screw off cap that locks behind the bulb, so where will the wiring exit and hookup to the ballast that will be mounted somewhere on the frame/fairings?
If anyone can provide pictures that would be GREATLY appreciated! Thanks
Old May 14, 2012 | 08:20 PM
The__Rider's Avatar
uh. bump?
Old May 14, 2012 | 08:22 PM
jeffjones's Avatar
Not to sure without a pic but ddm has a lot of downloadable instructions.
You may need a step drill bit and drill a hole out of it to run the bulb through and use there included grommet to re-seal it.
Pngo12
Apr 16, 2012 03:18 PM
clockworkcbr
Mar 30, 2008 11:30 PM
rrasco
Oct 10, 2007 03:39 PM
dragonium25
Apr 20, 2006 09:27 AM
