HIDs with 08 1000rr
Just ordered a set of HIDs from DDM Tuning for my 08 1000rr. I was looking at the bulb housing for the headlights and wondered where the wiring will exit to connect to the ballast from the bulb. There's a screw off cap that locks behind the bulb, so where will the wiring exit and hookup to the ballast that will be mounted somewhere on the frame/fairings?
If anyone can provide pictures that would be GREATLY appreciated! Thanks
Not to sure without a pic but ddm has a lot of downloadable instructions.
You may need a step drill bit and drill a hole out of it to run the bulb through and use there included grommet to re-seal it.
