Fuse question
Fuse question
I was putting on new rear turn signals, installed the left side and tested it (worked fine) installed the right side and now neither work(nor the horn) I'm pretty sure the wires accidently touched beacuse everything was just loose. I was wondering if there's a different fuse for the turn signals/horn versus the rear tale/brake light? thanks and also where are the located (I figure behind the front fender) thanks Again
