FUSE GOING OUT
Old Feb 13, 2006 | 08:16 PM
Rajj's Avatar
Default FUSE GOING OUT
HELP !!!! I've replaced the ugly factory turn signals to LED. BUT the fuse for the gauges is blowing as soon as I Turn the bike on.
I've checked the wiring 4X and they are all connected well and secure from touching one another.WHAT COULD BE THE PROBLEM??????? and how can I fix it????
I've even tried a fuse 30,25,20,15 fuse type but the larger one seem to warm the wires and thats SCARY.
PLEASE HELP
Old Feb 13, 2006 | 08:55 PM
Anubis's Avatar
Default RE: FUSE GOING OUT
Do you have any inline resistors to install or installed? They also help Slow the Blinkig down to stock rate. Other than this I honestly couldn`t help.
Old Feb 13, 2006 | 09:51 PM
L8X's Avatar
L8X
any of the big techies wanna take this one?
Old Feb 14, 2006 | 01:31 AM
shoeman's Avatar
wire crossed you most likley have a + wire going to a ground
Old Feb 16, 2006 | 05:35 PM
streetfighter's Avatar
go back to the indicator resisters and check the way they are wired you have connected them incorrectly check the earth. Do you have the indicaters on when you switch on ignition as if they are not then something else may be the poblem as the cicuit is not live till indicater switched on . DO NOT PUT A BIGGER FUSE IN THAN RATED THIS WILL DAMAGE YOUR BIKE AND IT CAN CAUSE IT TO CATCH FIRE [sm=badbadbad.gif][sm=nothatway.gif]. If you cant sort it out i will have a look at wiring diagram and then tell you which to connect to . You can try disconnecting them and then reconnecting one at a time to see if one is faulty .If you want mor ehelp contact me on my email regards Ben
Old Feb 16, 2006 | 06:45 PM
MgA_ODEN's Avatar
ORIGINAL: streetfighter
Dont forget the front act as running lights so they are live if he wired to them.
Old Feb 18, 2006 | 08:21 PM
I forgot usa lights are different to uk spec .The wiring for the earth wiring here is green .check the positive has not touched it if you are using leds do they have resisters to reduce the blink rate or are they wired straight to to wiring if so in this case they would have less load so would only need a smaller fuse and they definately shouldnt blow fuses
mitch Awsome
Nov 26, 2024 07:34 PM
JC00
Dec 17, 2007 12:34 PM
jwp6114
Jul 11, 2007 09:25 PM
alex71783
Jul 10, 2007 04:19 PM
ox.
May 26, 2006 12:13 AM
