520 Chain and Sprocket Update
Old Feb 19, 2006 | 07:54 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default 520 Chain and Sprocket Update
Ran the RK chain and Vortex sprockets for 5K miles and here are the results:
stretch per 6 pins versus 530 with same mileage: + .0156"
overall stretch versus 530: +.297"
As you can see from the sprockets the aluminum rear has a small amount of wear. Probably has another 2K to 3K miles left in it. Front steel has minimal wear.
And I didn't baby this thing -- ran it hard from day 1.
Main difference I saw was that with the 530 D.I.D. I only adjusted the chain 2 times in 5K miles. 520 RK required 5 adjustments over the same mileage to keep correct slack.
Old Feb 19, 2006 | 08:38 PM
Calkidd's Avatar
Default RE: 520 Chain and Sprocket Update
Great information Chainstrecher, thanks for the info. Now if I can just remember what miles I put my sprocket on....
How did you do the measureements?
Old Feb 19, 2006 | 09:16 PM
Inside dial calipers. Measured several areas of 6 pins and averaged them out.
Old Feb 20, 2006 | 06:08 AM
Chaos's Avatar
nice work[8D]
Myfirstcbr
Mar 22, 2013 09:40 AM
BorderLineAlaska
Jul 4, 2012 10:46 AM
sixtwoishere
Nov 19, 2007 06:30 AM
deedub
Nov 16, 2007 01:20 PM
