BMC Filter on '08 1kRR
Old Apr 19, 2009 | 11:13 PM
ichlgo's Avatar
From RC51
"Honda's are definitely more applicable to this issue than the other manufacturers. It would appear that Honda spends more R&D time than any of the other manufacturers to insure that the intake system on their bikes is finely matched to the flow characteristics of the motor. The airbox is perfectly tuned to accept x amount of air thru the filters & deliver it to the carbs or throttle bodies in a metered volume & every thing works perfectly in sync in the state of tune they must be in to pass EPA Emissions testing. Typically an alteration of the filter leads to too much turbulent air entering the airbox & usually ends up either leaning out the motor or stalling the airflow altogether."
"What would be more beneficial for creating more horsepower would be a larger airbox, which would make a larger amount of air "available" for the motor to use as opposed to a greater volume of air that the engine would be "forced" to use if you went with hi flow filters or filterless. What you don't want to end up doing is putting more air into the airbox than the engine can mix with the fuel. If that happens then you have screwed up your air/fuel ratio & you will lose power."
Again, I am not dissing aftermarket air filters. I am just saying that our stocks ones are perfectly fine and should use that $$$ on something else.
Old May 8, 2009 | 03:39 PM
tupperwareracing's Avatar
all i have to say is if you have a bmc make sure to properly oil them regularly i have them on my 06 and 08 and i always recommend them
NC CBR1K
Jan 21, 2008 09:37 PM
usndocjaysin
Sep 21, 2007 10:18 AM
MeyekulBayrd
Aug 25, 2006 08:10 PM
ddvs
Aug 25, 2006 04:35 AM
scotty8583
Jul 26, 2006 01:00 AM
