1000rr misfire
Old Jun 22, 2008 | 05:18 PM
1000rr06's Avatar
Default 1000rr misfire
yeah i have an 06 1000rr misses some times for 10 seconds and sometimes for ten minute ride bought with 1800mi now has 3700mi in 2 months not easy on it but isn't it a little low milage for spark plugs to be going out tried to check spark plugs but can't get intake air cowl under headlight the one with the valve any ideas
Old Jun 23, 2008 | 05:24 PM
tjripper14's Avatar
Default RE: 1000rr misfire
Changing the plugs is a major deal on this bike. If you look inside the cowl where the flapper valve is there are bolts that hold the front part of the ram air in place. Also you need to pull the radiator bolts out and move it toward the front tireand then you will be able to move the ram air slightly forward and just enough room to get the plugs out. Make sure to disconnect all the hoses on the top of the ram air.
spoolie25
Jun 7, 2011 08:39 AM
DRUNKEDclown
Aug 3, 2010 05:40 AM
bluebeard
Dec 19, 2007 12:52 PM
Stargazer
Sep 24, 2007 10:03 PM
F2uCK
Sep 14, 2007 07:23 AM
