Start My bike!
I cant start my bike[:@] i dont know what to do gets spark and Gas. I think the carbs aint workin right, Well if you got any more mayjor ideas could you let me know thanks.
havent tryed that yet but i will and i know that the timing is right i checked and it has compression too. I think it has to do with fuel its not geting right some how but i will try the spray. the last time it was running it died on its side after a wreck i got into.
Try twisting the idle ****, to open the butterflies plates on the carbs. Turn 6 times to the left or right to open and close the plates.
If it stop turning one way, turn the other. Don't turn to many time because you can uncrews it out of it sit.
At every turn, try starting the bike
get an ohm reader and test the pulse generator. it should read between 450-600 resistance...if its anything other than that then its bad. set the ohm meter to Rx100...you have to take your tank off and its right in front of the battery with the other 4 or 5 electrical connections. its the 2 wire one with white/yellow and yellow wires. the connector on mine was red, but just look for those 2 wires stick the ohm meter in there and see what ya get. mine came back a big fat 0 which meant an open circuit...not good.
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
