New motor problems. Or maybe even the carbs?
Old Aug 4, 2009 | 03:34 AM
tripicana's Avatar
i would check the compression. should be atleast 120 psi? check the others, not good if they vary more than 10%.
Old Aug 4, 2009 | 06:31 PM
reeseychez's Avatar
Compression is well within normal range on all four cylinders.
Going insane.
Old Aug 4, 2009 | 06:38 PM
cbreric's Avatar
this is a weird one. I would double check that the wires are indeed going to the right cylinders, really sounds like the timing is off. you would be getting spark, just at the wrong time. it may backfire every once in a while if it is just dieseling, you get enough fuel in the cylinder and it compression ignites. worth a double check
Old Aug 4, 2009 | 11:50 PM
Marmle's Avatar
I would take some pics of your wiring and post them. From spark plug wires back to the coils.
SidePuddle
Mar 14, 2011 12:10 PM
cbrf2.3
Jun 14, 2010 10:01 PM
secretdestroyers
Oct 26, 2009 07:54 PM
ttyger07
May 22, 2008 03:41 PM
ttyger07
May 7, 2008 11:20 PM
