2013 cbr600 breaking problem
Ok so do you hear anything happening up front? As in when nothing happens? Does it say not work then you let the lever go then it does work right after? How are your pads up front? Have you had the system opened up at all? (As in a disconnnected brake line?) Is your brake fluid level at the proper level? Are you able to get the front wheel off the ground to attempt to duplicate the issue? Thanks.
Role
10-25-2013 06:25 AM
