600 Mile service
RE: 600 Mile service
Valves should be fine until 12k or so
honestly dealerships get a good bit of money calling it a "XXX mile Service" vs just calling it an oil change and looking over the bike
oil changes are simple, steering head bearings shouldn't be an issue at 600 miles, otherwise they are going to feel your brake lever pressure and look at the fluid (it should still be very clear) and check some bolts (any idiot can feel a bunch of bolts on the bike to make sure they aren't loose)
some dealerships will swear valves should be checked at the first service just in case but modern bikes won't need to be adjusted anywhere near that soon so I wouldn't worry about it
In terms of "getting full on it" after the 600mile tune-up / check-up / glorified oil change - I say go for it. I never shifted above 6-7k when in the first 600 miles, then once I got her back I now rarely shift below 7k rpm. TONS more fun in the upper rpm range - I just went over 1500 miles and still no problems whatsoever.
How often does everybody change their oil? I think the book says the next checkup is at like 4k miles but that seems too long to me to go w/out changing the oil...
The manual also says to check and lube the chain every 500 miles or less, just fyi.
