info about swap swingarm
Old 08-19-2015, 03:18 AM
Marco Marfè's Avatar
Default info about swap swingarm
hi guys,i want ask you a techinical question because im pretty sure that you know more better than me,when you want swap the swingarm whitch are the things to look? for example i saw many cbr 900rr with the aprilia rsv swingarm that looks very nice,if i would to the same but on the 954 what i should consider?
Old 08-19-2015, 03:34 PM
Conrice's Avatar
The fact that its a stressed member bike rules out 99% of the motorcycles in existence (including your RSV arm idea), unless you have access to someone who knows how to brace and modify aluminum beyond recognition (and it'd be cheaper/safer/better to completely fabricate your own at that point).
A 929 will go on, a VFR 800 will work (which you can use to also run Triumph and Ducati hubs/rims).
After that, there aren't any other options that come to mind. Some of the Duc arms mount in a similar fashion, but I don't think they work because of the spacing on the back of their engines.
Old 08-20-2015, 04:21 PM
it was just an idea,but i was thinking to something different than the 929 or vfr, one guy he wanted swap the rsv swingarm on his 929 but he couldnt.. anyway thanks for the answer =)
Old 08-20-2015, 10:17 PM
Conrice's Avatar
I've looked for a long time as I've lusted after an under braced swinger for the '54.
But take a look
954 swinger
929
Viffer 800
Compare the open middle part where it mounts on the pivot shaft to any swingarm you're looking at.
Here's an R1's
Kawi
S1000r
RSV
You'd have to cut the middle part out and then brace the swingarm so that it kept some rigidity after cutting it apart.
Old 05-01-2016, 05:35 PM
sorry for the late answer,the last time i read it but i forgot to answer (and i was sure that i answered),you mean this part?
what you mean for "then brace the swingarm so that it kept some rigidity after cutting it apart." to add more welds to make it more strong?
i found this: CBR 929 with the CBR 1000RR swingarm,
929 Swinging Arm Unit Pro Link Conversion 1000RR 2004 - Honda Motorcycles - FireBlades.org
nof900rr
02-17-2019 11:51 PM
Inknsteel
09-30-2012 10:34 AM
MMMichael
09-20-2010 06:21 PM
Bringingf2bak
F2 Tech
04-23-2010 03:22 PM
drewc87
06-09-2007 11:33 AM
Quick Reply: info about swap swingarm
