engine swap info
Old Jun 5, 2007 | 05:51 PM
drewc87's Avatar
Default engine swap info
a friend of my cracked his 929 motor when the bike was dropped. he got a 954 motor but is now knocking. sounds like a bottom end knock. does anyone know what internal parts can be swapped out between the two engines?
Old Jun 8, 2007 | 06:51 PM
drewc87's Avatar
Default RE: engine swap info
bump!!
Old Jun 9, 2007 | 11:33 AM
im4u2nv81's Avatar
I believe the difference in displacement was from the bore of the cylinder, not the stroke. So I would assume (assume, because I do not know for sure) that all the other inner mechanical parts...rods & crank, could be swapped. I would definitely put a new bearing set in though. No reason to crack open a case and not replace the bearings.
nof900rr
Feb 17, 2019 11:51 PM
Marco Marfè
May 1, 2016 05:35 PM
BHDJ F2
F2 Tech
19
Aug 16, 2012 07:31 PM
lilpaco
Jun 23, 2011 10:44 AM
Workwell
Jan 14, 2009 10:02 PM
