Varnish in cylinders
Old 05-02-2016, 01:53 PM
Lisandro's Avatar
Default Varnish in cylinders
Hi guys,
Today I have pulled out the carbies cuz the bike was not idling good ( I think problem is clogged jets).
When I took them a part I have found a kind of caramel varnish on cylinder heads - where booties attach- and also I have seen it on the "butterflies" - the ones you tune when you sync carbs-.
I have seen through plugs that bike is running rich, so now Im going to tune air-fuel mixture. 2,5 turns would be ok?
Do you think this varnish is just because of bike running rich? or I might consider gas quality, rust in tank, or bike sitting for some time?
Help would be appreciated.
UPDATE: I have remembered that last time I have synced carbs I did it with a home made device, that I built with hoses and oil inside. Some of that oil was sucked by the carbs and later burnt by exhaust.
I have realized "caramel varnish" could be oil, and I hope is just from carb sync.
Anyways, any help would be appreciated.
Best regards from South America,
Lisandro
Old 05-02-2016, 05:30 PM
Conrice's Avatar
Pictures, in this situation, would really help.
Old 05-03-2016, 09:08 AM
Lisandro's Avatar
Hi Cornrice,
Thank you for your reply.
I have already cleaned everything. I made the mistake on not taking pictures before. I took some pics now, where with a little imagination you can figure out how was that "varnish", as there is some still left.
Regarding jets, they were quite clogged so I think would start idling ok.
By the way, don't you know a fuel stabilizer or something I can use to avoid jets being clogged due to bike not running for some days?
Cheers mate,
Lisandro
Attached Thumbnails Varnish in cylinders-image00001.jpg   Varnish in cylinders-image00002.jpg   Varnish in cylinders-image00003.jpg   Varnish in cylinders-image00004.jpg
Old 05-11-2016, 09:06 PM
Conrice's Avatar
Wow, that's a lot of oil build up on those valves and ports. How's your oil consumption?
Old 05-17-2016, 01:13 AM
Lisandro's Avatar
Hi,
Bike has been sitting for some time, also has been leaking some oil through a seal that you have helped me to identify on diagrams to order it
Even though, oil level looks fine.
Old 05-17-2016, 07:06 AM
Conrice's Avatar
Well, if its been sitting and you haven't been putting a lot of miles on it, you won't notice oil consumption.
Even with a small leak - oil looks like its a lot bigger volume when its on the ground than it really is.
Gluaisrothar
01-17-2007 10:54 PM
HONDACHAD
12-11-2006 07:50 PM
dirtysanchez
08-18-2006 10:54 PM
98600F3
07-15-2006 09:26 PM
BigBri
05-17-2006 12:35 AM
Quick Reply: Varnish in cylinders
