Running on 2 cylinders??????
Old Dec 8, 2006 | 11:07 AM
HONDACHAD's Avatar
Default Running on 2 cylinders??????
hi, i have a 2001 cbr f4i it has been sitting over 2 years,the bike sounds like it is running on 2 cylinders.I have replaced the spark plugs and the coils are giving the plugs spark.Is there something else that could be causing this problem.The bike ran fine the last time i rode it (over 2 years ago).The bike has about 6,000 miles on it with no engine mods.
thanks for your help,chad
Old Dec 8, 2006 | 11:46 AM
pawel's Avatar
Default RE: Running on 2 cylinders??????
So, the bike SOUNDS like its running on two cylinders or IS IT running on two cylinders? There is a difference. Start the bike and pull the plug wires off one at a time to check which cylinders are working. You might also want to do a compression test to see if the rings didnt sieze in the piston.
Old Dec 8, 2006 | 12:06 PM
Jaybird180's Avatar
Let it reach full operating temp, have fresh motor oil then check compression, spark, and look for obstructions in the intake/ exhaust. I've even heard of people finding bird's nests in their bikes.
Old Dec 8, 2006 | 12:17 PM
e3gordon's Avatar
sounds like bad gas
Old Dec 8, 2006 | 12:35 PM
Brandon77's Avatar
All of the above. Could be anything if it wasnt stored properly.
________
Best rated vaporizer
Old Dec 8, 2006 | 12:53 PM
HONDACHAD's Avatar
it wasnt stored properly, its really my friends bike.it sat outside about a year under a canopy and it was stored in a basement for about a year and a half.it for sure had bad gas in it but i drained it all out,even though there could still be some in the fuel system.
Old Dec 8, 2006 | 01:31 PM
FATHEADS1KRR's Avatar
You prob have some gunk in the injectors. Before you tear into it you might try some seafoam in the gas...... let it run for a while, then let it sit for a day or two. Its gonna smoke, but don't worry about that, it'll go away when you get fresh/untreated gas back in it. I've tried other cleaners w/no luck at all, but the seafoam stuff really does work if you give it some soak time. Use about a 1/4 can in a full/almost full tank of gas. If the injector/s are stuck closed the cleaner may not get to em, but i've seen it work before. Worth $5 to give it a try anyway. If that doesn't work, pull the injectors out n soak em in 100% seafoam for a while. The stuff is flamable, but not as much as gas. Would let em sit outside tho, you don't want to be breathing it for very long..... will make your ********* fall off.
Old Dec 8, 2006 | 02:12 PM
cbr_newbie's Avatar
ORIGINAL: Jaybird180
u serious??? a birds nest??
Old Dec 8, 2006 | 04:02 PM
Jaybird180's Avatar
Yep. Member on another board had that
Old Dec 8, 2006 | 04:05 PM
cbr_newbie's Avatar
LOLZ! i would have freaked out ifsomeone brought me a bike to work on with a bird nest inside the engine....
