Honda cbr 600 f4 start problem
Hi all , first post, i hope u can help me out, I bought a honda cbr 600 f4 here in South Africa not too long ago, everything was fine untill a week ago , it started by if id turn on the ignition the dash lights would come on and as id push the starter button , they would trip , now i figure out and saw the starter relay solenoid under the seat, and of i touched it with my finger or wiggled it , everything would come back on and it would start, now if i ride the guages are jumping around like crazy and the bike is making a choking sound, I thought changing the starter relay would help, and it did for two days , no problems at all, and today its started doing the same agian , i would rrly apreciate any help
I had the same problem last year. If you have a multimeter, check if you battery if it has a good connection. I found out my cell on the battery was bad. (Replaced battery) How long have you had the bike? I replaced my regulator and my stator so that it will fully charge. Also make sure the bike is not flooded with your gasoline. I had to replaced my fuel pump too because the shop noticed that it wasn't delivering the right amount of gas. Other than that, it should start. Good luck.
