1997 Honda CBR 600 F3 Backfiring will not start...
Well its been a while since Ive got hung up on a F3 but this is sort of an oddball problem, whenever I try to start it all I get is backfiring...I have brand new NGK R sparks, and Cleaned carbs from honda, air filter is new, and I know its getting fuel because I took the sparks out and they were soaked in gas...so what i am thinking is its a timing problem?? any thoughts or suggestions? im goin to take the statorcover off tomorrow when i get back to work and check out the flywheel...if it is a timing problem how do i fix it?
iv not had this problem but i know that it is caused by over fuelling and cant see how timing would effect it. are you sure the carbs are setup correctly? have you tried bump startin it ? are the spark plugs the original type? are the spark plugs the correct distance? not sure if any of this helps but worth a think about
on
1 Post
Back track on what you have done. The only other thing that comes to mind is that your reg sh*t itself in the mean time.
