Manual Cam Chain Tensioner
Old 02-09-2006, 04:04 PM
Yammieboy's Avatar
Default Manual Cam Chain Tensioner
Okay, now that I've done the new member intro, here goes my first question for the CBR gurus out there. I think it's probably an easy one that's been asked many times before, but here goes.
My bike(96) has a manual cam chain tensioner that the previous owner put in. I just picked this bike up last week, so haven't yet delved into wrenching and tweaking on it.
Can someone advise on :
a)how do you know when the cam chain needs adjustment?
b)tips on how to adjust it properly
Thanks !
Juan
Old 02-11-2006, 12:39 AM
Yammieboy's Avatar
Default RE: Manual Cam Chain Tensioner
bumpitty bump.
Anyone? Please?[sm=hia.gif]
Old 02-14-2006, 10:06 PM
Well you shouldn't have to adjust it very much... maybe one or twice a season I would check it. Take your right side fairing off. Loosen the lock nut and the bolt and turn the bolt in by hand until it gets tight... just a little tight not 100 ft. lbs. Then back the bolt off 1/2 to 1 turn. I believe that is how far you should back it off. A little loose will not hurt anything.
Old 02-14-2006, 10:07 PM
oh yea then make sure you tighten the nut back down and put your fairing back on.
Old 02-15-2006, 04:07 PM
Yammieboy's Avatar
Hey thanks Transtransamlt1man !
How do you decide when it needs adjusting? noise on cold startup?
or just do it as you suggest, maybe a couple times a year as a preventive measure?
Thanks,
Juan
Old 02-16-2006, 09:07 PM
You might here a little tick coming from the cam chain if it is really loose but it shouldn't be with that manual adjusters. I would check it now since you just bought it then do it again maybe every oil change or so. Once its adjusted right the first time that cam chain does not stretch very much so it will not need much adjustment. Its not something to loose sleep over or anything.
Old 02-20-2006, 04:17 PM
Yammieboy's Avatar
Thanks man!
Old 09-14-2009, 08:51 PM
psychoclown33's Avatar
Default im retarded haha
i need to tighten my cct as well...can someone please walk me thru it so i do ef it up plz
mufinkrakr
02-29-2008 01:47 PM
tutman6
04-10-2006 04:20 AM
dpenuell
04-06-2005 03:30 PM
Quick Reply: Manual Cam Chain Tensioner
