Changed my accelerator cable, now won't crank
Old 03-25-2017, 07:59 AM
Ashley's Avatar
Default Changed my accelerator cable, now won't crank
Hi everyone,
As the title says, I changed the accelerator cable on my 1994 F2 and now she won't crank.
To put some bit of history in, I've only just bought the bike a couple of weeks ago and I've been fixing it up, I noticed the accelerator cable was frayed but also that the other (push) cable was not even connected, so I put a new one on and connected both the cables. I put everything back together, pretty certain it's all back as it was but now when I go to start I get nothing! Not even cranking.
I am quite new to bikes so I may be missing something really simple, but I can't figure out why she won't turn over after fitting a cable?..
Any help is appreciated
Ash.
Old 03-25-2017, 08:42 AM
74demon's Avatar
Is the kill switch in the correct position? The connections or wiring could have been damaged when it got moved.
Otherwise, retrace your steps, again.
Old 03-25-2017, 09:00 AM
Ashley's Avatar
Demon, you are spot in! Just checked the kill switch and one of the wires has come off, quick bit of solder and she should live! I knew it would be something simple!
Thanks for the help
Ash
Jordon Bent
01-22-2014 05:48 AM
demon87
11-06-2010 11:41 PM
Captlombardi
07-15-2010 08:53 PM
supersnake83
07-05-2009 01:56 AM
whiteflash
02-04-2009 09:46 AM
Quick Reply: Changed my accelerator cable, now won't crank
