1990 CBR 600F
1990 CBR 600F
Not getting any power to the starter. I turn the key on and the horn and signal lights work. But when I press the starter button nothing. Starting doing some small checks that I know and no spark either when I cross over the solenoid. The starter turns excellent.
Anybody ever come across this problem?
Thanks in advance......
RE: 1990 CBR 600F
Try this...
Check the 30A fuse ( in starter relay ) and all the 10A fuses on the fuse panel. The oil pressure and neutral switches have individual bullet connectors (under the gas tank as well) on the right side of the R/R connectors.
Order of components is as follows...
1. Battery
2. 30A fuse in starter relay
3. Ignition switch
4. 10A fuse ' G'
5. starter switch
6. starter relay coil
7. clutch switch then ground OR diode then neutral switch then ground
1. Battery
3. Ignition switch
4. 10A fuse ' G'
5. starter switch
RE: 1990 CBR 600F
If it IS the starter button, buy a NEW one, rather than chancing a used one. I bought a used one, but I'm never positive if it'll work or not, since ebay is like that.
Bikebandit carries thhe starter button assembly, without the whole cluster for $90 before shipping, I'd imagine ronayers, servicehonda, or some similar site may have it cheaper.
