Rear lights not working
Old 06-05-2014, 06:59 AM
hmm's Avatar
hmm
hmm is offline
Default Rear lights not working
1990 CBR1000F-L.
Noticed as I got off the bike today that both rear bulbs are not working when the ignition is on.
However they both light up when the key is in the Park position, and both brake circuits light up for both front and rear braking.
Where should I start looking? Doesn't sound like a fuse to me.
Thanks all.
Old 06-05-2014, 08:13 AM
Sprock's Avatar
Check the wiring in the tail area first, sounds like it's not wired proper
Old 06-05-2014, 08:34 AM
Colombo's Avatar
The brake light on my F4i suddenly stopped working two days ago as well.. the running lights work but the brake light does not. I figured it was a bad brake light switch but I tested the continuity and its fine. I later discovered that by tapping on the rear (aftermarket) LED tail lamp... the brake light would actually work. I'm thinking for me its a loose connection.
Have you done any recent changes such as replace the tail lamp or add any other electrical things to the bike?
Old 06-05-2014, 11:39 AM
hmm's Avatar
hmm
hmm is offline
Thanks Colombo.
Not done any electrical work lately apart from removing heated grips.
It probably is loose wiring somewhere, I'm just puzzled why the bulbs light when in Parking mode.
I'll have a look tonight or over the weekend.
Old 06-05-2014, 04:27 PM
hmm's Avatar
hmm
hmm is offline
Default It was a fuse
Yup, it was the fuse after all. Thankfully (and unusually for me) a simple fix - unless it keeps blowing.
The following users liked this post:
A1A (04-24-2022)
bringit609
04-20-2010 07:08 PM
F4iFreak
03-30-2008 09:24 AM
sacking16
07-12-2007 11:09 PM
Ocelaris
12-07-2006 02:14 PM
crookedeyemotocross
05-23-2006 12:53 AM
Quick Reply: Rear lights not working
