Clutch issues
Old 03-08-2015, 01:38 PM
Alexanderfitu's Avatar
Default Clutch issues
Hi all
Got the bike up and running after a while and a I have a slightly odd clutch issue. If I operate the clutch repeatedly with the bike on the side stand, the biting point moves closer and closer to the handlebar until the clutch cant be released completely.
To temporarily fix the bike has to be leaned to the right and the lever operated repeatedly and it brings it back.
Im thinking the fluid needs changing and the Master cylinder seals need changing, is there anything else that I should be doing?
Old 03-08-2015, 02:35 PM
Sprock's Avatar
master and slave seals , the slave seal on the sprocket cover being the most likely culprit
best to do both though
Great, I thought as much, I will do both and renew the hose as it looks original! Thanks.
ssftheone
F2 Tech
04-17-2014 10:56 AM
sinister
03-05-2011 02:54 PM
dwarfdwarf
02-23-2011 11:01 AM
DunnRR
05-19-2010 11:25 PM
a_bomb30
09-10-2007 07:20 AM
Quick Reply: Clutch issues
