Balancer/ chain noise at lower revs?
on
1 Post
Does the engine balancer/chain rattle at all at idle and low rpm/low or little load conditions if it has not been checked in a long time? My cam chain and tensioner are new but there is still noise. Alternator chain checked last year and tensioner was ok.
Only time the balancer will make a noise if it's too tight - makes a sort of groan/squeak noise.
Oil pump drive chain may rattle as said above, camchain rattles always (unless you fit HenryM's amazing modification)
Sometimes it's something as simple as your chain tapping on the swingarm if the rubber boot protector is worn (and the chain's a bit slack)
