600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
fork swap?
Old 11-01-2011, 10:53 AM
TAVERY75's Avatar
Default fork swap?
I have a 2000 f4 with bent forks. I've been told i can use forks off any f4i,929,or 954 model between (1999-2004) Is this true and if so will i need a new tree or extensive modification to make them work?
Old 11-01-2011, 02:17 PM
gotcbr's Avatar
Welcome to the forum.
You can use any F4 ('99-00) or F4i forks ('01-06). The F4i forks are externally the same as F4 forks...internally, there are minor differences. So, you can do a direct swap for F4i forks. Simply pull your old fork tubes & replace w/ F4i tubes, done. <---That is the easiest & cheapest solution. F4i forks are easily & readily available on ebay, etc, for inexpensive cost.
While you can adapt other model forks, you'll have to make modifications & your handling will change. The direct swap w/ F4i forks is the best way to go.
Malcolm Morrow
F2 Tech
17
03-02-2012 11:13 AM
jordan f4i
03-25-2011 09:05 PM
40oztofreedom
10-12-2008 09:07 PM
axsys
06-28-2007 04:44 PM
grwilson6
02-20-2007 08:27 PM
Quick Reply: fork swap?
