600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
F4i shock swap......anyone tried?
Old 07-07-2007, 11:25 AM
gag1938's Avatar
Default F4i shock swap......anyone tried?
I was wondering if anyone had experimented witha shock from an F4i. It is longer which doesn't bother me. I want to know how the spring rate compares. I have one at the shop and I will try it unless anyone has had a bad experience. I plan to rais the forks in the clamp to level it out. I could use some more clearance in the gravel anyway.
Old 08-05-2007, 03:05 PM
ajlong's Avatar
Default RE: F4i shock swap......anyone tried?
What type of bike are you looking to put it on. The F4'sand F4i's are about 375lbs dry, so you can let that be a guage, but as far as actual spring rate, dunno? sorry, just thought the stats might help.
Old 08-06-2007, 05:09 PM
Tahoe SC's Avatar
the stock shock spring is rated for about 150 lb rider.
Old 08-06-2007, 06:40 PM
Frankenstein's Avatar
I am running an F4i rear shock on my F2, the rate is a little soft, I weigh 205lbs, but for street use it is fine. If I were running at the track I might go for a slightly stiffer rate but I would be comfortable doing a track day with it as it is. Consequently, the slightrake decrease in addition to the increased front weight bias really woke up my F2's turn in.
Hootie233
03-04-2011 01:08 AM
woot
11-05-2009 02:51 AM
land_warrior.rus
12-29-2008 10:29 AM
njdjh2o
06-05-2008 04:38 PM
Loomis
04-18-2008 01:27 AM
Quick Reply: F4i shock swap......anyone tried?
