Advice after F4 Shock swap...
Old 12-26-2008, 02:17 PM
land_warrior.rus's Avatar
Default Advice after F4 Shock swap...
I replaiced my standart rear shock to he one from F4 and noticed iproblem.
he chain is robbing off the swing arm alot more and swing arm frotector that is located between the chain and the swing arm wears very fast to the point that chin has started to wear the swing arm itself now. I chaned the rubber swing arm protector once olerady but the new one is worn already, not good, considering that they neather if the twoo is cheap to replaice.
know that the shock mod i performed is very popular roud here so looking for some info on possible solutions.
BTW, the preload spring is already all the way in..
Cheers.
Old 12-27-2008, 01:54 PM
Default RE: Advice after F4 Shock swap...
BUMP
Old 12-27-2008, 02:28 PM
how is your chain slack? are you within spec on that or no?
Old 12-29-2008, 10:29 AM
the chain slack is OK.
SneakyMcC
09-12-2011 04:54 AM
mustang082780
10-18-2008 09:12 AM
Loomis
04-18-2008 01:27 AM
MikeInCtown
01-16-2008 06:30 PM
gag1938
08-06-2007 06:40 PM
Quick Reply: Advice after F4 Shock swap...
