tire size
tire size
my f2 is half way there to becoming fully stunted out. ..yes.. a F2. F*CK F.I!! haha jk jk. it has a 12 bar, sprockets, clip ons. just need a cage, aceribis headlight and a hand brake! well anyways i was thinkin, since my f2 stock rear tire is a 160/60/17, would it be better for balance and control if i put a 170 or maybe even a 180 on the rim? i know it wont help for street riding, but would it help for circles and better balanced and controlled wheelies?
No not on the f2 wheel. You might be able to run 170mm if you get a f3 wheel. 160 pilot power is all you need. I've got a acerbis cyclops headlight with a left bulb out. Might cost 5 bucks to replace. Ill let it go for $70 shipped. Has 2 holes for a zip tie in the number plate so you can hide all your wires behind it without to much work. I had the fuse box right up there for easy access. Ive also got a 12 bar ill throw in for 40 bucks. Have to pick up some hardware for it though.
