Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
Cant wheelie help
Old May 16, 2010 | 09:43 PM
utter05's Avatar
March 2009 ROTM
Default Cant wheelie help
I am on a 97 F3 with stock gears.
In first gear i ride up to 7500-8000 rpm let of till
5000 rpm and then hit it hard again. the wheel only
gets up a couple feet at most and most of the time barely
lifts off the ground. What am i doing wrong or what else do
i need to do to get up to my balance point.
Old May 16, 2010 | 10:41 PM
johnnyh's Avatar
I never did do power wheelies, to dangerous and unpredictable. Clutch it up, works every time. I clutch up my 600rr in 2nd and 3rd easy. Once you can clutch up just practice a little at a time and don't rush things. Johnnyh
Old May 17, 2010 | 12:56 PM
Sick97SS's Avatar
+1 on clutch ups. Just goto a large parking lot and practice all day.
MUCH better than pow-pow-powa wheelies.
Old May 17, 2010 | 11:33 PM
rideoncbr's Avatar
clutch wheelies are the only way, that is unless your happy riding short wheelies, no matter what anyone says, clutch wheelies are the ideal way to go, anyone who says otherwise obviously cant ride long wheelies, especially on a inline 4 600, by the time you get one powered up, your out of juice
Old Jun 29, 2010 | 11:26 PM
antatious's Avatar
I don't know if you have wheelied other bikes before, but definitely use your clutch. I just learned how to wheelie on my F2 after learning for a solid 3 hours on an XR 80. Before I started wheelying the xr 80, I was only getting my F2's front up about a foot like you probably are. I could power wheelie or clutch it up only a few inches, but never get the feeling like I could flip my bike if I stayed on the gas.
Literally, after learning to get the XR 80 to 12 oclock position while slow rolling and using the clutch, I got my F2's front wheels off the ground a good 3-4 feet the first few tries. If you are not comfortable getting your machine's front end off the ground- try it with a bike half the weight of yours. It helped me tremendously. I just made a post about it actually.
Old Jul 2, 2010 | 12:40 PM
Baooo's Avatar
try practicing clutch up in 1st gear first cause if you can perfect 1st gr wheelies you can transition better to 2 and 3d. Lot harder to go from learning them in second to 1st gear just my opinion
shardoflard
Jun 22, 2009 12:28 PM
scorpion2420
Oct 14, 2008 02:58 PM
KingKong
Aug 31, 2006 09:18 PM
stephygee
Aug 19, 2006 02:55 PM
