Any one running a hand brake?
![Icon Doh](https://cbrforum.com/forum/images/smilies/icon_doh.gif)
if it was for f4i then it should work and you mustve not known what to do
dual cal is better but the adapter will screw in like its supposed to if you got the right one for the bike
I run this handbrake:
http://www.solomotoparts.com/catalog...s-p-22454.html
with this clutch:
http://www.solomotoparts.com/catalog...s-p-31338.html
I love it, had no problems, have plenty of braking power, it's kind of hard to bleed because it replaces your rear reservoir, as you connect your front master cylinder directly into your rear master cylinder...
I just angled the whole unit down more than normal so I could reach the clutch comfortably...
with this clutch:
