Stunt/crash cage
im looking to build a stunt/crash cage I think i can do it cheaper then buying one please if you have one on you f2 /f3 post pics of it so i can get a good look at one thank you
you're probably going to get better response from this on the stunter/streetfighter forum. Just cause it seems that for the most part the active folks here are not in the stunting mode. Could be some lurkers though.
Google image search for CBR F2 cage and you get a decent selection of results - seems that most all are homemade cages, so there's some stuff to go on.
I have the "905 Racing" cage for racing with no under-bar for stunting. Just the simple racing cage. I like mine and helps takes away the frame sway. I did the GSXR fork swap with Fox twin-clicker rear shock and was met with a fluid like sway in deep hard corners. Found out the frame was the weakest link after that. Advised to get a cage and bought the 905 frame cage. Immediate stiffness and replicates a newer beefier frame. Yes, it does stick out further from the frame but it helps with the rest of the bike being robust and more responsive after my mods. Adds only 15lbs too. Plus, if you have fairings(mine is a Ratted Streetfighter) you will never scrap paint, maybe your exhaust a little.
