underground-mpyre |
11-07-2012 11:57 AM |
I have the "905 Racing" cage for racing with no under-bar for stunting. Just the simple racing cage. I like mine and helps takes away the frame sway. I did the GSXR fork swap with Fox twin-clicker rear shock and was met with a fluid like sway in deep hard corners. Found out the frame was the weakest link after that. Advised to get a cage and bought the 905 frame cage. Immediate stiffness and replicates a newer beefier frame. Yes, it does stick out further from the frame but it helps with the rest of the bike being robust and more responsive after my mods. Adds only 15lbs too. Plus, if you have fairings(mine is a Ratted Streetfighter) you will never scrap paint, maybe your exhaust a little.
