Opinions on headlight setup?
I'm sorta new to the bike scene, and I just purchased this bike and one of the few things I dont like about it is the Cyclops headlights on it. They are really dim and just dont go with the bike I dont think.
What would be some good swaps or bolt on headlights (or simply modded setups) to run on it, and keep the fighter look?
Something like this?
Let me know your opinions or what you guys have done.
And it is a PIECE OF SH*T! It basically goes for all of those Taiwanese headlights. There are also some that are made in America - and they're a lot more expensive. While I haven't personally used those, I've heard they're very similar.
A) They have very specific bulbs. They look like your basic "run of the mill" 1157 bulb from any auto store. However, they have this little ridge on the rim by the plug that won't let you use an 1157. I was only able to find them at a local scooter store.
B) The bulbs started blowing very often. I averaged 1 a week! (While I was waiting for my new V-rod headlight - I ended up going through at least 2 a week)
C) The cheap plastic melts
D) If you think you can't see anything at night with your Acerbis - wait until you run those - I couldn't see ANYTHING. And then the light would blow out!
If you're like me at all - I wanted to keep the headlight close and tight. I didn't want the headlight to stick out. These headlights stick very far out. I eventually cut and modified it so it would fit right. The overall design looked pretty good - but it ended up being a real POS.
Unfortunately, that old adage about getting what you pay for really rings true with regards to headlights. Those Buell headlights are very good. And as far as good headlights go, they're pretty cheap.
I'm using this on my fighter. MT-03 headlight
I've also used this. V-rod headlight
I liked the V-rod, it just didn't go with my dirty bars. But, if you're keeping clip-ons, I think it'd look great.
I do really like that MT-03 light setup. How hard was that to mount up to our bikes? And I understand what you mean about the cheap lights. I just meant a setup like those, with a little plastic around it but a good light. Something small and sleek. I will definitely look into that MT03 light.
I think it would tie in the front alot better with my bike. And if it is an OEM headlight setup it HAS to be better than this Amazon special. Now, where to find a good one that doesnt cost an arm and a leg?
I tried the $45 type masks - and as you could see from my first post - they suck. I then used a V-rod headlight (and I got it for around $100 on ebay). After that, I sold it and saved up for the MT-03 light.
Now, those Buell headlights are a helluva lot cheaper. And they're projectors - which is nice. As an OEM piece, they actually hold up over time too. Plus, there's lots of left overs at Harley dealerships that the dealers are not too keen on keeping, you could always make an offer on them and see if the dealer would accept it.
I will definitely look into a set of those Buell projectors then, but see what I can do about switching that setup around though, since the fairing piece that is with it also houses the gauges and such.
01-03 HONDA F4I GAUGE BRACKET - $49.00 : On-Point Performance, Motorcycle Stunt and Performance Parts
