1995 CBR F3 Bobber/Fighter
Hey Colorado Steve what did you use for the fairings back when you had the stock f3 seat on there. I have an f2 I bobbed, and the seat needs some plastic behind it, and I want to build something over the subframe. I was thinking wire mesh, but I'd rather have something substantial.
So if you could tell me what/how you made the fairings right under the seat that cover the subframe, that would be awesome.
I love your bike, definitely want to cut up my factory plastics to make a belly pan. DId you just cut yours and refinish em?
Thanks, and keep up the awesome work.
Colorado Steve:
I have an F3 that I am doing a similar build on and was wondering what you did with the direct air injection hoses that are integrated into the front plastic under the headlight. I read in the manual that it is for when you are going 12 mph or less. I am wondering if I can just take it out or while the performance of the bike be altered. What did you do with these? I like your headlight and I am planning on keeping it simple with just the 7" headlight and some vapor gauges.
Colorado Steve:
all of this was originally posted by Kuroshio and explains how to bypass it:
The solenoid is circled in the pic.
To bypass it:
Disconnect the electrical connection from the harness
Disconnect hose 11 from 10 and recover the joint (16)
Disconnect hose 5 from the solenoid
Using the joint, connect hose 5 to the air hose leading into the carbs (on the opposite side of the solenoid)
That disables the solenoid and bypasses the tiny intakes. All air to the carbs will come from the ram duct now. You can completely remove the solenoid and disconnected hoses if you like.
That's helpful. Quick question though, would disconnecting the sensor require a jumper where it's connected at the harness or can that part of the harness be removed? I like the progress! Keep up the good work!
Thanks for the info this is exactly what I was looking for! Ill give it a try might be a while till I get to find out if it works or not since my bike is not all together currently. I'm sure I will have more questions and I probably should start my own build page.
no jumper needed, just disconnect it. i did remove the wires from my harness
since there seems to be a few questions on this here are some better pics of the end result of air solenoid bypass. this is fat head's f3 from custom fighters, hopefully he does not mind that i am borrowing his pictures:
here is a link to his build thread on custom fighters, its f*cking awesome
http://www.customfighters.com/forums...318#post250318
