Drag a knee correctly
I read this on another forum and found it interesting.
http://www.yamaha-forum.net/forum/showthread.php?t=4171
Heh the 2nd from the last pic, the guy following looks like he's thinking "Oh God, I'm gonna be in a picture with someone looking that stupid
But I think the top pic does raise the question of which ones are actually wrong. I mean I can think of a time when you might want to look like the guy in the 2nd illustration: counter-balancing during a tight low speed turn. Think it'll all be rather situational. So long as you don't look like the guys in the last 2 pics
EDIT: I looked at the pics better. The bottom right is the best of the group, but the bottom left is good except he's not over far enough. Combine the two, not bad.
WHAT I SAID IN THE ORIGINAL POST: I prefer a position between the two (not completely hugging my tank but not riding high).
not sure if i agree with the last two frames in the first picture, i always see pros with their head way low,
and if you think about it, if the centrifugal force is the same, then in the last frame it would be pulling the bike over more compared to the 2nd to last frame, since the cog is higher in the last from and farther away from the tire.
although im sure there are many variables, plus theres no such thing as centrifugal force haha
I looked at the pics a little better, the guy riding high isn't bad because he's at least on the inside of the center line; the guy crouching has got a good crouch, but is in-line with the center line. Combine the two (get lower and to the inside of the center line) and you're great...like the above picture.
