Only on a track do I downshift, but I never upshift without the clutch in....hint hint. I use GP shift, so my gearing is backwards(1 up /5 down) on both my racebike and streetbike.
I tried it this AM, ironically, before seeing this thread. :)
<sorry for digging up a slightly old thread> The CBR upshifts without the clutch just as easily as any japanese dirt bike I've ever been on. Downshifting works, too, but as has been said, you have to work a bit more to make revs want to match properly in order to avoid excessive shock loads on the tranny. As a side note: You can shift any automobile without the clutch, too, although you'll ultimately wear things such that you'll make it want to pop out of the gear(s) you clutchlessly shift to most. As with OTR trucks, you _must_ match revs with your foot off the clutch pedal to accomplish this safely and successfully, but I've done it literally thousands of times. I find the big trucks to be easier to shift w/o the clutch than synchronized gearboxes in cars. |
i am going to try shifting up without the clutch now... i always thought that it would be bad news for the tranny but everyone is doing it haha
I find that when trying to get up to speed fast that shifting without the clutch is a good thing and makes the shifting faster. But under normal conditions I just use the clutch. Either way
I use a pringel air shifter. It works great for fast shifting under wide open throttle :-).
This thread is hilarious. Thanks for bumping it.
If you have a Power Commander just add the Dynojet Quickshifter. With it you can do full throttle clutchless upshifts.
Originally Posted by backdoc
(Post 1026275)
They ARE nice to have on the track though....for street it's absolutely useless unless you're just trying to be cool/a douche bag. |
Originally Posted by DrAwkwArD
(Post 1026354)
The quickshifter isn't "full throttle" as it cuts the engine momentarily to allow for the shifting. It's the same as letting off throttle except you don't have to do the hand movement.
Originally Posted by xricer
(Post 1026457)
So you're saying clutchless up shift = douche bag? Or power commander upshift = douche bag?
