Riding Skills Want to improve your skills on or off the track?
Clutch and brake grip
Old Apr 14, 2012 | 01:58 PM
kowen1208's Avatar
Default Clutch and brake grip
What fingers do you use to grip your clutch and brake levers?
I use middle and ring finger on both hands. I find that I get a better grip on the throttle that way, and maintaining throttle control under braking is one thing I really try to work on.
Old Apr 14, 2012 | 06:08 PM
BorderLineAlaska's Avatar
I do the same mostly but I catch myself wanting to use more than that from time to time. Sometimes I use 3(all minus my pinky) for the clutch and then my pointer and middle for the front brake. I don't know if this is a bad habit or not.
Old Apr 14, 2012 | 08:19 PM
MadHattr059's Avatar
I ride with 3 on the clutch (sans pinkie) and 2 on the brake lever (index and middle, last two stay on the grip).
On the street, you should maintain these fingers on the levers, at all times.
The 3-5 hundreths of a second, added, mean you have traveled (at least) an additional
20-30 feet, these are critical numbers in a near-collision scenerio.
Trust me on this...I once put my front tire, 1" past the face of my front door-with
the door closed. Ooops, not gonna do that, again!
Good luck and ride safe, Ern
Old Apr 14, 2012 | 08:53 PM
kowen1208's Avatar
Those doors just jump out at ya sometimes.
This video Kuroshio posted is what got me thinking about it. My index finger doesn't reach far enough around my brake lever to get a good pull on it. Maybe with different levers I could.
BMW S1000RR - David Johnson - YouTube
Old Apr 14, 2012 | 09:59 PM
He's using a radial piston master cylinder on his brakes. They are more efficent and need less travel and lever force. Here's a link to how they work...
Overview of a Brembo Master Cylinders
For us regular folk, try the adjuster on the lever to bring it closer to the grip.
Just don't get it so close, that you bump the bar, before full pressure is exerted.
Ern
Old Apr 20, 2012 | 11:10 AM
Wisconsin's Avatar
3 on clutch 2 on brake.
Cover most of the time, not when accelerating hard though.
Fordhamjc
Jun 5, 2013 02:17 PM
vfrman
Mar 1, 2012 05:44 PM
Shadow
Alternative Parts
Sep 2, 2009 01:42 AM
93cbr600
Dec 25, 2008 06:37 AM
jaboyak
Jan 28, 2007 01:43 AM
