Turn Signals
I had a set of those on my old 02 f4i. ( they were on the used plastics I bought on ebay after a wreck) They worked ok, and I painted the lil rear cover part to match the bike, which looked good. Not very unique, but for $18, I'm guessing your not trying to win any motorcycle show !!
I had some similar to those on my F4i. I had to shave off the lip around the area where the stock signals mounted to the fairings. The only two major problems I had was that I couldn't change to anything else once I cut off those lips to smooth it down, and once I overtightened the screw that held on the cover and it broke part of the inside so it would never sit tight against the base. Other than that, I think they looked good and they were fairly bright.
They work really well but you have to drill into your fairing and they are rather large. I had a set on my red F3 and i painted the black portion of the turnsignal red so they weren't as noticable.
I like the ones i have they have 2 small wires coming out of that back and thats it the rest is a big sticky pad that you have to cut down to fit you bike . Also you have to run leds or something if you state requires amber's. I tucked mine in to the vent holes cant see them to well from the side but it looks good up front. Ill pull the mids off thisweekend and post a better pic of the underside.
[IMG]local://upfiles/15648/6D4ECF60E81A4815A613E417C86C7EB0.jpg[/IMG]
[IMG]local://upfiles/15648/E8300DAC01C54F97A1404FDF6DDC9679.jpg[/IMG]
Lowridese
May 1, 2010 01:12 AM
