2011 CBR600F - Not coming to the USA
What gives, another great bike not coming to the US market...
Specifications – CBR600F (E-type)
ENGINE
Type
- Liquid-cooled 4-stroke 16-valve
- DOHC inline-4
Displacement - 599cm3
Bore ´ Stroke - 67 ´ 42.5mm
Compression Ratio - 12 : 1
Max. Power Output - 75kW/12,000min-1 (95/1/EC)
Max. Torque - 64Nm/10,500min-1 (95/1/EC)
FUEL SYSTEM
Carburation - PGM-FI electronic fuel injection
Throttle Bore - 36mm
ELECTRICAL SYSTEM
Ignition System - Computer-controlled digital transistorised with electronic advance
Starter - Electric
Battery Capacity - 12V/8.6AH
Headlights - 12V; 60/55W low and high
DRIVETRAIN
Clutch - Wet, multiplate with coil springs
Clutch Operation - Mechanical; cable-actuated
Transmission Type - 6-speed
Final Drive - #525 ‘O’-ring sealed chain
FRAME
Mono-backbone; rectangular-section gravity die-cast aluminium
CHASSIS
Dimensions - (L´W´H) - 2,150 x 740 x 1,150
Wheelbase - 1,437mm
Caster Angle - 25°
Trail - 99mm
Seat Height - 800mm
Ground Clearance - 135mm
SUSPENSION
Type
Front - 41mm tension and preload adjustable inverted HMAS cartridge-type telescopic fork, 120mm stroke
Rear - Monoshock damper with adjustable tension and preload, 128mm stroke
WHEELS
Rim Size
Front - 17M/C x MT3.50
Rear - 17M/C x 5.50
Tyre Size
Front - 120/70 ZR17M/C
Rear - 180/55 ZR17M/C
BRAKES
Type
Front - 296 x 4.5mm dual hydraulic disc with three-piston calipers, floating rotors and sintered metal pads
Rear - 240 x 5mm hydraulic disc with single-piston caliper and sintered metal pads
ENGINE
Type
- DOHC inline-4
FUEL SYSTEM
ELECTRICAL SYSTEM
Starter - Electric
DRIVETRAIN
FRAME
CHASSIS
Wheelbase - 1,437mm
Caster Angle - 25°
Trail - 99mm
Seat Height - 800mm
SUSPENSION
Type
WHEELS
Rim Size
Rear - 17M/C x 5.50
Tyre Size
BRAKES
Type
new bikes have less and less plastics.... they look semi streetfighter, and not so sporty anymore. i think well designed plastics for the whole engine compartment would make the bike look more track and less street. but thats just my opinion.
Nope. That's why they have a RR. That's why they went to the nanner seat in '04. The RR replaced the F4i as the 600 sport bike. They nanner seat made it a "sport tourer."
I did a bit of looking around on this and it seems Honda did a nice job at offering accessories for it which is nice. They've got a factory under, tail hugged, tail bag, passenger seat cowl, and a few other things. Really wish they would bring this over to the US in the next couple of years. We all know it took them forever to bring over the 250, maybe in a few we will see it. I would probably put the f4i up for sale to get one of these. In one of the articles I read the super sports sales are down and more people are looking for a slightly higher seating arrangement than laying over an RR tank. Maybe it's wishful thinking, but yamaha and Suzuki I know are on the bandwagon making detuned super sport models with the more upright seating.
Just get an f2 0r f3. This bike is a faired hornet (599) which is based off the f3. So it's an f3 with a backbone frame instead of twin spar, fuel injection, USD forks (though only preload adjustable) and bigger brakes. I'll take one. Ohhhh, not in the U.S.? Well poop. f3 it is
krazyderek
Europe, Asia, South America, Africa, Austrailia, Antarctica
Jun 1, 2013 06:51 PM
