2005 cbr 125 wont start
Old Sep 23, 2024 | 04:58 PM
colind1's Avatar
Default 2005 cbr 125 wont start
went to start my cbr the other day, and it is dead. was running fine when i put it in there.
no lights on the clocks.
the battery is good. the fuses are all good.
i checked and there is no power coming through the main fuse.
i changed the starter solenoid,and the regulator.
if you put live power direct to the the main fuse the clocks light up, but wont start , because there is no spark.
dont know what else to try.
Old Sep 24, 2024 | 12:59 AM
Ed Harris's Avatar
How have you checked your fuses?
If you have 12.8 volts or more across the battery and zero volts after the main fuse then either the fuse is blown or the wiring from the battery to the fuse is broken. The state of the starter solenoid and the regulator is irrelevant.
Fix the known problem and then we can move on to finding why you have no spark if that is still a problem.
Old Sep 26, 2024 | 01:18 PM
colind1's Avatar
alls fine. went to check the electrics under the tank and the ignition connector fell apart. rewired it and now it all works. just got to try and free up the choke now as it has locked up in the carb.
Old Sep 26, 2024 | 08:52 PM
Ed Harris's Avatar
Thanks for letting us know what the problem was, enjoy 😊
ssina24
Apr 16, 2023 05:32 PM
Gabe Gillespie
Aug 6, 2022 03:45 PM
Kevin Quan
Apr 18, 2018 02:04 PM
Deekster
Apr 15, 2012 12:13 PM
jadilla
Sep 19, 2008 12:20 PM
