XBox E74 Error
RE: XBox E74 Error
ORIGINAL: rangerscott
Its a pc crammed into a tiny box. They will all fail eventually.
RE: XBox E74 Error
Cellphones dont give off enough heat to destroy themselves.
Oh and apple's iphone fell victim to overheating also, not enough to cause a recall or burn people, but enough for you to pick up your phone to use it and go "WTF?!"
RE: XBox E74 Error
If itĀ“s an overheat issue, you can try blowing out the system with canned air. Dust acts like insulation. Also, try to keep the unit a few inches off the floor and definitely off carpets. DonĀ“t smoke in the room, this causes systems to get dirty fast!
More than likely, if you are having this problem, it is too late to fix. IĀ“m not sure about the system designs, but overall dust is the biggest factor. They jam up cooling fans block vents and act as insulation, preventing heat from dissipating correctly.
