who's in orlando with garage and tools?
Old 05-10-2006, 10:58 PM
TwistedCBR's Avatar
Default who's in orlando with garage and tools?
Ok, i did all the work but now i am STUCK
the stator is stuck on the stator cover, the damn bolts that hold the stator in WILL NOT COME LOOSE
any ideas?
Old 05-10-2006, 11:34 PM
baja74vw's Avatar
Default RE: who's in orlando with garage and tools?
Ok, I just noticed this post after your PM.
What style allen wrench are you using? L shaped or a multi-style flip out tool?
If the L shaped, can you put a small cheater bar on it? Those bolts are most likely loctited on as you don't want them to loosen.
Tim
Old 05-10-2006, 11:48 PM
TwistedCBR's Avatar
i've tried both and the multistyle nearly began to strip one of them...bad idea!
you know i never relaly had good luck and then to try and fix the bike myself was just foolish cant get the damn stator cover back on properly either, lol
keeps going to low ARHAJRLKJAKLSRJ
Old 05-10-2006, 11:59 PM
TwistedCBR's Avatar
this J&B blaster crap....works?
Old 05-11-2006, 12:02 AM
baja74vw's Avatar
Ok, you have the cover in the house. Good start. I would call that the hard part!
Use the L style allen. Only one that fits snug! Otherwise, they strip and you are screwed!
You need to add a cheater bar to the allen if you are not able to do it with your hand. Find a small dia pipe or use a combination wrench and ghetto style:
You just need to break the loctite loose.
Try this and let me know!
Tim
Old 05-11-2006, 12:03 AM
If you have access to a torch, you can heat the part where the bolts go into, and it'll cause it to expand and they should come out pretty easily.
Old 05-11-2006, 12:05 AM
TwistedCBR's Avatar
i live in apt complex...i have access to a pool, gym, car port to wash cars, dumspter, tennis courts, but no torch
Old 05-11-2006, 12:06 AM
TwistedCBR's Avatar
ughhhhh be back in 20mins trying this out AHHHHHHHHHHHHHHH
Old 05-11-2006, 12:12 AM
baja74vw's Avatar
ORIGINAL: 94CBRF2
Now, that is funny!
I know you have an oven! Put the cover in at 200 or so degrees for a little while to heat the aluminum. Aluminum expands faster than the steel bolts. Oven mitts and careful work and the bolts should come right out.
This will make you house stink and your roommates may no think it is funny. I used to powdercoat in ours. (Not healthly!) My roommates did not care because all we did was build cars and bikes and all the oven did was cook a pizza every now and again at 3am.
Tim
Old 05-11-2006, 12:31 AM
TwistedCBR's Avatar
roommates would completely flip out
2 out of the 4 are good...other 2 began to strip so i stopped but they will completely strip threads if i keep going
the wiring one is out
any ideas on the 2? other then in the oven
Quick Reply: who's in orlando with garage and tools?
