View Poll Results: 48÷2(9+3) = ????
54.55%
288
25
45.45%
Voters: 55. You may not vote on this poll
Are we smarter than bodybuilders?
Old Apr 9, 2011 | 10:32 AM
  #141
jp_greenville13's Avatar
Old Apr 9, 2011 | 02:18 PM
  #142
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
You guys do this for fun in your spare time?
Old Apr 9, 2011 | 04:07 PM
  #143
mike.bucci's Avatar
so everybody wins and nobody feels like an idiot!
Old Apr 9, 2011 | 05:12 PM
  #144
PlayfulGod's Avatar
phuq no I HATE math lol
Old Apr 11, 2011 | 11:51 AM
  #145
Xander F4i's Avatar
For those of you who are claiming the distributive property:
48/2(9+3)=
48/2*9+48/2*3=
216+72=
288
You can't use the property half way and call it complete...that like driving from Philly to Cleveland and saying you are in Chicago.
Old Apr 11, 2011 | 02:43 PM
  #146
jeffjones's Avatar
48/2(9+3)=
48/2*9+48/2*3=
216+72=
288
That only works for fractions, where as this was written with a division sign.
The easy way to solve it is what I learned in like grade 9 and check your answer.
If you take your answer (as you get it) 48÷2(9+3)=288
then you should be able to substitute an x into any of the values and when you solve for x you will get that value.
For every correct answer in math this will work.
So for those that get 288 can someone please prove this wrong.
48÷x(9+3)=288
and show me how you get x=2.
Because in any answer you get for math it can be proved.
Old Apr 11, 2011 | 02:47 PM
  #147
jeffjones's Avatar
Originally Posted by regener8ed
seeing this problem one way or the other is not necessarily a "mistake". i just prefer one method over the other because of the apparent contradictions in application that can arise, as demonstrated.
the fact is, a) the problem is poorly written at best but probably better described as flawed. b) the solution to this problem depends on who (or what) you ask (and how you were trained): strict mathematicians seem fairly evenly divided on the issue, while the vast majority of engineers see distribution as the determining factor. computer programmers are likely to resolve it using order of occurrence, since that's how most programming languages would be designed to handle the problem. (by the way, it is not uncommon to create custom programs to handle the idiosyncrasies of algebraic grammar, of which this is but one demonstration. claiming one solution simply on the basis of "that's what C++ returns" is not a universally valid argument. even more so to say that "that's what google returned.")
this has been fun to watch; the debate on this forum has been WAY lass volatile than others -- amazing how a little string of characters can divide people.
I've been waiting for someone to bring this up, so yes; let's consult Wolfram on this one:
But wait...
...interesting.
And from yet another source:
And I think everyone's seen all the variety of results returned by different calculators. Technology is not making things any clearer here.
Because of the algebraic rule that says if you're dealing with variables you resolve an equation one way, but if there are constants you use another way? No thank you. A lack of consistency is all part of the problem to begin with.
Last, an excerpt from some educational material:
I think this is the best post in this thread saying that it is a poorly written question.
Great research lol.
Old Apr 11, 2011 | 03:43 PM
  #148
Xander F4i's Avatar
---(9+3)=
now maybe that will help the people figure this out
Old Apr 11, 2011 | 03:52 PM
  #149
jeffjones's Avatar
48
---(9+3)=
Thats the exact same as:
48x(9+3)
or
48(9+3)/2
But neither of those look like the original question.
If like in every single math question out there (That is written correctly) you can substitute an x for any value and work backwards like previously stated.
x=9
48÷2(x+3)=2
This works when you do the math.
x=9
48÷2(x+3)=288
This doesn't work, and I am not changing any parameters of the question.
Just checking my work just like every single math equation that is true will allow you to do.
Old Apr 11, 2011 | 04:17 PM
  #150
Xander F4i's Avatar
48x(9+3)
-------- this is the same equation as the original
or
48(9+3)/2 As is this
x=9
48÷2(x+3)=2 this is a FALSE math equation! To make this equation true should read: 48÷[2(x+3)]=2 which is a different equation!
x=9
48÷2(x+3)=288 this is TRUE!
the only reason that you say it works or doesn't work backwards is because you aren't working it backwards properly!
The equation originally posted in a word problem would read 48 divided by 2 times the sum of 9 and 3, the answer to which is 288. To get an answer of 2 it would need to read 48 divided by the quantity of 2 times sum of 9 and 3.
