View Poll Results: 48÷2(9+3) = ????
54.55%
288
25
45.45%
Voters: 55. You may not vote on this poll
Are we smarter than bodybuilders?
Old 04-08-2011, 06:22 PM
jeffjones's Avatar
Originally Posted by jp_greenville13
You are STILL using the distributive property!!! which does not work for this equation! lol
explain why you can't use it when it is there.
  #112
rocketsauce035's Avatar
I said 2 and agree with jeffjones and the methods he has mentioned
  #113
Old 04-08-2011, 06:23 PM
mike.bucci's Avatar
i thought it was 2 from the start and still do but......
Originally Posted by regener8ed
this one has tickled me - i posed the problem to 8 other engineers in my office and got these answers:
288 [none]
2 [7]
well that's poorly written [1]
i've also emailed the question to my dad, who in fact is a rocket scientist, and for me, his answer will be law.
what does dear old dad have to say on the issue?
  #114
Old 04-08-2011, 06:25 PM
regener8ed's Avatar
no matter how you look at it
but if i use your previous method i get:
(4 * x / 2 * x) which is: 2x²
  #115
Old 04-08-2011, 06:27 PM
jp_greenville13's Avatar
I have a socket set in my tool box. Why can't I use the 14mm socket on a 12mm fastener? It's there isn't it?
Because it doesn't fit and it does not work! Sure I could try to use it. Is it going to work right? Hell no!
  #116
Old 04-08-2011, 06:28 PM
bluedevil3758's Avatar
jeffjones: ill break this down for you
when you put the 48 over 2(9+3) your changing the problem, because then you evaluate the entire top an entire bottom before dividing, however when you write a division symbol you are just dividing the 2 number adjacent to it.
This is what confuses everyone, as usually you can split the problem into top an bottom, but in this problem it affects the answer, thus the confusion
Also i have 4 years of university math, calculus I,II,III differential equations, probability, plus all my engineering course, blah blah blah i have met the biggest dumbasses in college an you can pass all that stuff doesnt mean anything if you dont know how to apply it
  #117
jpanside@gmail.com's Avatar
Parenthesis imply multiplication. Therefore
48/2(9+3)=48/2*(3+9)
jeff you missed the memo or were sleeping in class
the * is not required to explicitly show that multiplication is being asked. The parentheses tells you. This is basic high school algebra.
Order of Operations:
Rule 1: First perform any calculations inside parentheses.
Rule 2: Next perform all multiplications and divisions, working from left to right.
Rule 3: Lastly, perform all additions and subtractions, working from left to right.
Keep it simple; yes, you can use distributive property to answer the question (I posted it twice for you) but you keep violating the OoM while using it so I think it is confusing you.
The OoM says that you must first attend to calculations within parentheses. Therefore, we first add 9 + 3 and get (12):
(9+3) = (12)
This leaves us with
48 ÷ 2(12)
As you can see, there are two different computation symbols in play. First, we have the division sign that looks like this: ÷
Next, we have a multiplication calculation between the 2 and the (12), implied by the parentheses.
The 2nd rule of OoM states that multiplication and division are of equal "rank" and the order is dictated by going from left to right. Thus, since the division is on the far left and the multiplication is on the far right...you divide 48 by 2 first, and then you multiply the answer by 12.
How can you multiply 2(12) first, when there is clearly a division computation in front of it (48 ÷ 2)?! Are you really not seeing this?
There is no difference between these equations! ----> 48/2(9+3)=48/2*(3+9)
Either way you are getting 288
  #118
Old 04-08-2011, 06:30 PM
Touche
  #119
Old 04-08-2011, 06:31 PM
this problem is 2(x)^2 as i mentioned in my last post, in most problems when you see a division sign you can change the problem to top/bottom but in some problems if affects the problem,
so here we have 4*x/2*x so its 4x/2 = 2x*x so 2(x)^2
  #120
Old 04-08-2011, 06:40 PM
jeffjones's Avatar
(9+3) = (12)
This leaves us with
48 ÷ 2(12)
Maybe you were asleep in Basic high school algebra.
Distributive property
The distributive property comes into play when an expression involves both addition and multiplication. A longer name for it is, "the distributive property of multiplication over addition." It tells us that if a term is multiplied by terms in parenthesis, we need to "distribute" the multiplication over all the terms inside.
2(5 + y) = 10 + 2y
Even though order of operations says that you must add the terms inside the parenthesis first, the distributive property allows you to simplify the expression by multiplying every term inside the parenthesis by the multiplier. This simplifies the expression.
So therefore you do the distibutive property before you do multiplication or division
Quick Reply: Are we smarter than bodybuilders?
