View Poll Results: 48÷2(9+3) = ????
54.55%
288
25
45.45%
Voters: 55. You may not vote on this poll
Are we smarter than bodybuilders?
#101
jeffjones: you should ask for your money back...
48/2(9+3) if you want to distribute the 2 you have to distribute the 48/2 = (216+72) = 288
its like if you had xy(9+3) it does not equal x/(9x+3x); just remember * an / have same importance so you work left to right if there is a x*z/y = xz/y not x(z/y)
#102
you can't add symbols and change the equation and expect a correct answer.
the 2 is distributed between both the 9 and the 3.
thats what 2(9+3) means regardless you have to simplify that before you can do anything which is:
2(9+3)
=(18+6)
=24
The only way to do it the other way to get 288 is add a bracket (48/2)
or remove the distributive law from the question and add a multiplication.
If I didn't take years of univerisity math I would be saying it was 288 as well.
But the whole problem is no mathematician would ever write a equation in this format.
#103
How is it a false property?
2(9+3)
=(18+6)
=24
2(9+3)
=(18+6)
=24
#104
#105
It's a false property in this instance because if you use it it changes the answer that you get by calculating it the way that it is written
Parenthesis imply multiplication. Therefore
48/2(9+3)=48/2*(3+9)
This is not adding a symbol or changing the equation. It is simply showing a symbol that is not shown.
I would say I agree with blue devil that you should ask for your money back but you can't expect to be taught common sense for a price. If the tool doesn't fit then you can't use it (in this case the distributive property)
You can't use a 14 millimeter socket on a 12 millimeter fastener.
You can't use the distributive property on this equation.
They don't work.
Every other way you figure it out will lead to 288. If you can show me another way to solve this correctly that gives 2 as a result... Edit: without using the distributive property ........then I will eat my words.
They don't work.
#106
____
2(9+3)
=(216+72) ?
Pass that **** this way it must be good.
you are right about xy(9+3) = (9xy+3xy)
but the 48 doesn't have anything to do with the 2(9+3).
the 48 is the numerator and the 2(9+3) is the denominator as the original equation is written.
all your doing is taking the (9+3) from the denominator and putting it in the numerator for no reason?
because what your saying is the equation looks like this:
48*(9+3)
______ = 288
because that is the same as:
48
__ * (9+3) = 288
They don't work.
Every other way you figure it out will lead to 288. If you can show me another way to solve this correctly that gives 2 as a result then I will eat my words.
They don't work.
Ok I will substitute an x for the 2 in the equation and make the equation equal 2.
48 / x(9+3)=2
48 / 9x +3x=2
48 / 12x=2
48 / 2=12x
24=12x
24 /12 = x
2=x
#110
