Virtual Memory?
Old Jan 19, 2009 | 01:41 PM
DDCavi's Avatar
Default Virtual Memory?
So I ambyfar not a computer guy at all. Recently Ive been having a pop up saying my virtual memory is low. Its causing everything to slow down horribly. How do I fix this? Itsa Compaq Presario lap top.
Old Jan 19, 2009 | 02:18 PM
shawnyc01f4i's Avatar
Default RE: Virtual Memory?
Are you connected to the internet when you get this? Try disconnecting from the internet and see if this still occurs.
D2VW14_20's Avatar
You sure its not a spam pop up.
Old Jan 19, 2009 | 02:27 PM
ORIGINAL: D2VW14_20
LOL thats what I was getting at, it sounds like it but its tought to tell without seeing it
Old Jan 19, 2009 | 02:31 PM
Nauree's Avatar
Retards. It means you have too much crap on your hard-drive. Either delete stuff or get more physical memory
Old Jan 19, 2009 | 02:35 PM
ORIGINAL: Nauree
I came close to filling my hard drive many times and it never said "Virtual Memory" it says "Hard Disk" or "C Drive".
Old Jan 19, 2009 | 02:41 PM
travsstuff's Avatar
virtual memory = RAM........
when was the last time you turned your computer off?....try doing that. Programmers are notorious for having memory bugs in programs, they allocate memory and then dont give it back to the OS when they are done with it....this causes your RAM to slowly fill up....just turn off your computer and let your RAM refresh for a few seconds and you should be good to go again.....get some more RAM too
Old Jan 19, 2009 | 04:17 PM
Nauree's Avatar
ORIGINAL: travsstuff
Dude
virtual memory != RAM.
When your physical memory is fully used, your computer uses your hard drive as a memory storage device. Your computer allocates space on your hard drive to use it as virtual memory. When you have too much crap on your hard drive and not enough physical memory then you get that message.
Old Jan 19, 2009 | 04:18 PM
Nauree's Avatar
ORIGINAL: shawnyc01f4i
ORIGINAL: Nauree
You probably also had plenty of physical memory or wasn't running any memory intensive programs.
Old Jan 19, 2009 | 05:21 PM
TechTrix's Avatar
http://letmegooglethatforyou.com/?q=virtual+memory+low
