Virtual Memory?
So I ambyfar not a computer guy at all. Recently Ive been having a pop up saying my virtual memory is low. Its causing everything to slow down horribly. How do I fix this? Itsa Compaq Presario lap top.
RE: Virtual Memory?
Are you connected to the internet when you get this? Try disconnecting from the internet and see if this still occurs.
RE: Virtual Memory?
You sure its not a spam pop up.
RE: Virtual Memory?
ORIGINAL: D2VW14_20 You sure its not a spam pop up. |
RE: Virtual Memory?
Retards. It means you have too much crap on your hard-drive. Either delete stuff or get more physical memory
RE: Virtual Memory?
ORIGINAL: Nauree Retards. It means you have too much crap on your hard-drive. Either delete stuff or get more physical memory |
RE: Virtual Memory?
virtual memory = RAM........
when was the last time you turned your computer off?....try doing that. Programmers are notorious for having memory bugs in programs, they allocate memory and then dont give it back to the OS when they are done with it....this causes your RAM to slowly fill up....just turn off your computer and let your RAM refresh for a few seconds and you should be good to go again.....get some more RAM too |
RE: Virtual Memory?
ORIGINAL: travsstuff virtual memory = RAM........ when was the last time you turned your computer off?....try doing that. Programmers are notorious for having memory bugs in programs, they allocate memory and then dont give it back to the OS when they are done with it....this causes your RAM to slowly fill up....just turn off your computer and let your RAM refresh for a few seconds and you should be good to go again.....get some more RAM too virtual memory != RAM. When your physical memory is fully used, your computer uses your hard drive as a memory storage device. Your computer allocates space on your hard drive to use it as virtual memory. When you have too much crap on your hard drive and not enough physical memory then you get that message. |
RE: Virtual Memory?
ORIGINAL: shawnyc01f4i ORIGINAL: Nauree Retards. It means you have too much crap on your hard-drive. Either delete stuff or get more physical memory |
RE: Virtual Memory?
